Can see IP camera image everywhere but NVR?
Des
Likes
2
Thread starter #1
Just can work this out.
I have hard wired ZXtech IP camera working many months, stopped seeing image via NVR(ZXTech)
I can see image on IE and Onvifer just not on NVR
I have changed IP address same result
Changed resolution on cam software & NVR several times no change
Changed Streams, Changed Frame Rates, switched everything on and off (apart from router & switch), changed stuff I dont know what it does.
IPs all outside DHCP range
I dont know where to go now. All other cameras (3) fine
I have made no recent software updates. I view my cams via the NVR ip address and login through IE
Having laid out my problem visually, I think I will try resetting to factory default next
Phil
Likes
191
#2
Just a quickie, do you have a monitor connected to the NVR, and if so does the problem camera show-up on the direct-connected monitor OK?
Des
Likes
2
Thread starter #4
Phil, sorry took route of least resistance. This camera always loses all settings as soon as power is cut and reverts to default IP address. I cut power for one second, found it (via NVR) on default setting, changed IP back to original - now all good!
As a supplementary , do these cameras have a battery or capacitor that fails, so settings lost immediately power is cut?
Phil
Likes
191
#5
It's hard to know for any brand, but that is typical of older electronic devices; although not something we typically experience nor have feedback from customers of with IP cameras and NVRs.
