Cat5 install help please
jim239
Thread starter #1
Hi everyone,
I have cracked on with installing my CCTV, I have run a few cat 5 cables and tested them successfully using my Haydon tester. Unfortunately after running a length through some conduit I have found that my tester is flashing both pins 1 & 2 simultaneously and then cycling through the other pins correctly at one end, the other end flashes fine.
Will I have to replace the whole cable or will my Hikvision turret camera be ok with the 1 & 2 pins, I guess crossed? I am unsure if the camera uses those pins?
I have replaced both ends and redone the connection but it has not fixed the problem.
Thanks for any help
Regards
Jim
Phil
#2
If your cable tester fails the cable, then it is unlikely to work with a camera :(
jim239
Thread starter #3
I have tried replacing the connectors again with no luck and now additional pin 4 not working.
I am going to try again incase it’s just me messing up the connections and if it fails I will replace the cable and start again.
it’s frustrating as I don’t know where the issue along the cable is as it’s all in conduit and I don’t believe it got damaged putting it through.
jim239
Thread starter #4
Third times a charm, I changed the plugs and they tested ok.
I have three cameras up now but am scared to power them all up and add them on to the network.
