Convert standard lense to wider angle??
marc.knuckle
my eyespy247ext+ is great apart from the relatively narrow angle of view.
is there a way to somehow attach an aftermarket lense like wide angle to improve this?
Marc
looking at the info on the eyespy247ext+I don't think this would be easy (if possible at all) as it has a board mount lens. In addition to this the I/R illumination will probably be configured for the lens that the unit comes with so fitting a wider angled lens may not give the desired results. It may be worth calling eyespy direct 0845 5440 288 to see if they can porovide a lens or solution.
