Dahua PTZ and NVR compatibility
Carlh2269
Will a dahau nvr work with a dahua ptz?
The dahua has rj45’s with no where to connect the ptz rs485 and coax output wires. Any help out there to clear this up?
Kyle
Hi @Carlh2269
Do you have the model numbers of the Dahua PTZ and NVR that need to be connected, or a picture showing the connections on the NVR and camera?
The PTZ is likely an analogue model as it has a coax output, which will need to be connected to an analogue DVR which has coax inputs, rather than an NVR which can only be connected to IP cameras (due to the RJ45 inputs).
