Disabling IR LED's on Vivotek Cameras
Harri Whipp
On some occasions you may want to change the settings of your camera to disable the IR lights on the device.
To do this is very simple. Log into your camera via its IP address.
Click ‘Configuration’.
Next click on the ‘Video’ button.
On the next window, click on ‘Day/Night Settings’ to open a drop down window for IR settings and cut off settings.
Here you may opt for B/W images in night mode, how you would like the IR cut filter to work and how sensitive you would like the light sensor to be. You can also choose to enable or disable your IR lights.
If you would like to disable the IR lights just check the box that says ‘Disable IR LED’.
To save these settings, just click the save button at the bottom of the screen.
