Doorbell DS-KB6403-WIP - wifi dropping out
bucoops
Thread starter #1
Good evening all,
A couple of months back I bought one of these doorbells, got it working on wifi easily enough, and got it also recording to my NVR. Worked fine for about 3 days then several times a day it would lose wifi connectivity and shout out that it had lost it. Every other device in the house has a rock solid connection and the WAP is a Unifi AC-Pro which is accessible over the road - in other words it's NOT the Wifi availability, it was the doorbell. I returned it as faulty, but am under pressure again to get a replacement.
Is this a known issue with these doorbells or was I unlucky and got a faulty one? Can anyone recommend an alternative if it's likely to occur again? At present I'm 100% Hikvision but as long as compatible with my NVR (DS-KB6403-WIP) and there's a user friendly app then I would consider it.
Phil
#2
Hikvision's wireless cameras etc. are generally very good.
You will find hundreds of Posts in this forum - very few regarding wireless / wi-fi issues.
StewartM
#3
What firmware is your DS-KB6403-WIP on? Recent firmware release notes for the DS-KB6403-WIP mention 'Fixed failures of WiFi connection'.
Another consideration, I believe only 802.11b/g/n is supported by the DS-KB6403-WIP. The Unifi AC-Pro might be prioritising 802.11ac.
bucoops
Thread starter #4
Thanks Phil and Stewart. I believe it was on the current firmware (looking at the most recent firmware it was released June 2018?) - the device said it was up to date when it checked.
The Unifi has separate radios for AC and the older protocols, and we have a laptop connected most of the time without issue and a couple of other older devices that aren't AC and again never have any issue.
Dan
#5
Latest firmware for the WiFi Doorbell is v1.4.62 Build 180515
Please login or check SADP to see if the doorbell is running this version or not.
bucoops
Thread starter #6
Apologies Dan, I missed your reply. As above, I returned the device, but I did check for a firmware update at the time and it said up to date. I can't be certain it was on the listed one above, only that the device itself said no update available.
