DS-7608NI-I2/8P
V4.51.005 build 210628
with:
1. DS-2CD2365G1-I - V5.6.5 build 200316
2. DS-2CD2355FWD-I - V5.6.5 build 200316
3. DS-2CD2355FWD-I - V5.6.5 build 200316
4. DS-2CD2555FWD-IS -V5.6.5 build 200316
I've update my ageing NVR for a DS-7608NI-I2/8P and have noted some interesting behaviour.
If configured using HTTP I can get live view and playback on Safari on Mac (I thought this hadn't worked for a while?) and Chrome on Windows. I can however only view one Stream1 at a time (the other 3 cameras will fail to view), can not playback more that one synchronous stream at all, but can view all four on stream2 in a 2x2 window.
If changing the config to HTTPS, view playback on Safari and chrome fails, only working on IE with the plugin installed.
All cameras playback if using the NAT'd address (192.168.254.x) directly on all browsers.
Also noted as an aside, if the new NVR is left as Plug&Play, the default gateway (manually entered) does not survive a reboot. Granted, the cameras were not defaulted from the configuration when on the previous NVR (should this matter?), but turning off Plug&Play and setting manual makes this work, so that I can send emails directly from the cameras.
Is this normal behaviour? I'm wondering if this is the cause of issues with Mac browsers? I've tried importing the certificate, but that didn't help.
Stuart
with:
Stuart
