Hello
I bought the DS-KD8003-IME door bell.
I was able to get it up and running (and updated) and changed the netword protocol to SIP because I don't want to have a hikvision indoor station with its limited functionality.
I then made a SIP server with FreePBX, witch only the ulaw and x264 codecs enabled. Afterwords I set up some softphones with only those codecs enabled.
I changed the IME1 settings to call the correct extension and connect to the sip server.
When I push the button of the doorbell, I hear it ringing and my softphone gets an incoming video call. When I answer it, the softphone says call is in progress but I have no sound or audio. The doorbell just continues ringing for a minute or so until it times out.
When I let 2 softphones videocall each other, everthing works fine. I tried changing the call station to another softphone with the same problem. I tried running the PBX server on a raspberry pi and on a virtual machine with same results.
Anyone have any idea how to fix this?
