Door Entry Extend distance between the door station and indoor unit?
alanm1973
I have a 2 wire Hikvision DS-KIS702 video door entry kit with an extra indoor unit (total 2 indoor units). I set the whole thing up in the house using short lengths of parallel 1x2x0.5mm cable joining the 1 door station DS-KD8003-IME2 and the 2 indoor station DS-KH6320-WTE2 to the DS-KAD704 this was connected via Ethernet cable to a router. All set up and functioning well, everything visible on the network. I then take the door station and fit it at the gateway. I hadn't realized that there was a limitation of 100m and the gateway is around 150m. The door station powers up but is offline. Would purchasing a DS-KAD706 and placing this part way between the door station at the gateway and DS-KAD704 in the house help? Or is there another solution?
This kit was bought to replace a non ip 2 wire video system from Bticino which worked but didn't have any of the additional features offered by the Hikvision system.
