Facing IP Address redirection issue
rafaelsolano
Hi, I am facing a IP address URL redirection issue. Basically, I am trying to connect my CCTV camera on the same network as of my WiFi Router but the default IP address is redirecting me to a different address. I have even tried the router login website - 10.0.0.1
How do I fix this? Thanks in advance.
Regards,
Rafael
I'm not sure I've understood your question.
If you run SADP on a PC on the network it will show the camera's current IP address etc.
If you tick DHCP, then your router will issue the camera with a valid IP address.
You can then untick DHCP and leave the camera's IP address fixed where it was set.
