Have two wireless cameras with the same ip in my nvr
nicoacosta8
Hi!
I bought a Longse 4 wireless ip cameras + nvr kit.
Two of the cameras are properly assigned to the ip addresses 172.20.18.13 and .14. But the other two are added with the same ip .11 . So when I unplug the ethernet cable from the camera connected it keeps changing from one camera to the other.
How can I change the ip of one of the cameras in order to be able to use both of them wirelessly? (Notice that the ip that allows me to use them wirelessly is different to the default ip of the camera)
I hope you can help me.
Thanks in advance!
Are you able to reset one of them back to default?
(using a pushbutton on the camera or similar)
Then disconnect and reconnect, and hopefully the NVR will assign a new/correct IP address.
No particular experience with Longse products, just based upon typical behaviour of IP cameras and NVRs.
