Hi, looking for some help,
A.B
I have connected 3 ip cameras in the house with router , mobile and cams close to each other as per instructions,all connected fine and worked, when I unplugged them and moved outside none work, no internet , I have a wavlink poe outdoor antenna / repeater in between the cams and router, the repeater has the same wifi key as the router any help would be great thank. UPDATE, I have just repeated the operation but I took the router outside connected all cams again, when I disconnect the router and take back inside reconnect the power , same thing again, all cams have no internet. Why do they lose the wifi signal when moved ? HELP.
Presumably, the cameras, when mounted outdoors, are out of the range of your router's wi-fi.
Hi Phil, not according to the mobile signal strength and I use a wavlink outdoor antenna/range extender, total distance from router to cameras is less than 30 mtrs with the antenna in between.
