Hik Connect Streaming Issue
alexkemsley
Thread starter #1
I have a hik deep in mind nvr but when we try and stream out of network its very slow and jumpy.
Its fine in network and also find out of network on playback.
Can anyone point me in the right direction.
Alex
Phil
#2
NVR model number?
Are you running the latest firmware? (check the portal)
You mean live view in the App is not good?
Android or IOS?
What's the internet connection at the NVR site like?
Especially the uplink speed?
alexkemsley
Thread starter #3
Thanks for your email in repsonse:
iDS-7732NXI-I4 / 16P/16S(B) model
V4.1.61 build 190624
4.52 Mbps upload
Android app.
Phil
#4
There are newer firmware versions available here:
HIKVISION UK PORTAL
It is always worth updating to the latest available version, in case Hikvision have resolved your issue.
alexkemsley
Thread starter #5
Thanks for your help Phil. Have updated but same issue. Anything else to try. Seams to start off well with the stream then tail off to nothing. Have basic streaming reaolution set too.
Phil
#6
Could it be roaming data limitations (poor data signal), or is it the same when you are wi-fi connected at another site?
For reference, which Android device are you using?
