Hikvision and Synology DS214+ - connection
stonefox
Hi.
Is it possibel to create a setup for my Hikvision cameras save both snapshot, motions pictures and video recording to a unique folder on the Synology DS241+ ?
Not the IP-camerafunction on the Synology is it to expensiv for my 5 cameras.
I have true to setup Synology FTP opload, but only Pictures be saved, and not the recordings !
Another question, How can I copy recording from the Hikvision SD card and to my computer without moving the SD card ?
Unfortunately, you can't do this without using Synology's surveillance station, which as you know will require you to obtain the appropriate camera licenses. You can add two cameras to surveillance station for free, after that, you'd need the additional 3 licenses.
You can access the recordings on the SD card by navigating to the camera directly. Lets say the IP address of your camera is 192.168.1.100, go to this address to open the camera in your browser, then head over to the playback window, select where you want to go to in the calander, and you can hit the download button to get the clips you want.
