- 5,013
- 113
Hikvision have today shared this additional detailed information regarding AcuSense.
Shared here for its clarification on the maximum of four cameras using false alarm filtering in the NVR:
Do SMB customers want the latest intelligent surveillance features without a full system upgrade? With Hikvision, they can enjoy the benefits of cutting-edge false alarm filter with an average of 90% accuracy while protecting their existing investment.
False alarm filter is one of the most intelligent features of modern surveillance systems. Designed to filter out movements from things like rain, leaves and animals, these systems focus on movements by relevant objects like people or vehicles. This prevents time and costs being wasted on non-threatening events.
Saving time and cost is important for Small and Medium-Sized Businesses (SMBs), the question is, how can they access such innovative technology in the most cost-effective way possible?
Tech-savvy surveillance...
Hikvision's EasyIP 4.0 security solution features intelligent false alarm filter within its AcuSense NVR and IP camera ranges. Currently, a Hikvision AcuSense NVR supports up to four camera channels with false alarm filter.
Hikvision AcuSense-enabled devices can filter out false alarms with an average of 90% accuracy. What's more, the AcuSense Quick Target Search feature saves time by identifying footage of people and vehicles automatically, avoiding staff having to search through footage manually. Add in Hikvision's ColorVu IP cameras, which provide full color, vivid images even at night, allows customers to take advantage of false alarm filter around the clock.
...that's easily accessible
For SMBs looking to access these features in the most efficient way, Hikvision's cameras and/or NVRs can be added to their existing surveillance system, to provide reliable false alarm filter capabilities while protecting their investment.
Below, we describe four different ways Hikvision false alarm filter can be added to SMB customers' surveillance systems.
Solution 1: Conventional IP cameras + AcuSense NVR
If SMB customers do not want to replace their existing IP cameras, they can keep them, and add an AcuSense NVR. This will support false alarm filter and Quick Target Search across four channels.
It is possible to add extra channels, but these will only have traditional alarm detection features. This solution is best suited for users who only need false alarm filter in four camera locations.
Solution 2: AcuSense IP cameras + conventional NVR
Conversely, if customers would prefer to keep their existing NVR, AcuSense IP cameras can be added to the solution.
It's worth pointing out that this is most suitable for customers that need false alarms to be filtered out in real time. A conventional NVR will not record or display the false alarms, as the functionality resides in the cameras. Similarly, users cannot search the alarm information delivered by the cameras as the NVR does not support Quick Target Search.
Solution 3: ColorVu IP cameras + AcuSense NVR
ColorVu cameras deliver bright color video images, even in low light and at night. When paired with an AcuSense NVR, SMB customers get a system that delivers highly effective false alarm filter, plus Quick Target Search capability, around the clock.
The only limitation of this setup is that it is designed to deliver the above features to a maximum of four channels. It is possible to add more channels, but these will only display normal alarm information, and will not support Quick Target Search.
This solution is best suited for customers needing reliable false alarm filter under low light conditions and across four locations.
Solution 4: AcuSense IP cameras + AcuSense NVR + 4-ch conventional IP cameras
When customers need false alarm filter for more than four camera locations, a cost-effective solution can be delivered by combining conventional IP cameras with AcuSense IP cameras and an AcuSense NVR.
Because both the AcuSense NVR and AcuSense IP cameras support false alarm filter, the functionality starts to overlap when only four AcuSense IP cameras connect to an AcuSense NVR. It is recommended to apply both products when customers need the function for more than four channels. To be specific, customers can connect up to four conventional IP cameras to an AcuSense NVR for false alarm filter, and then using AcuSense IP cameras for the remaining channels. In this way, both false alarm filter and Quick Target Search will be available across all channels.
Discover more
When it comes to an analogue surveillance system, it is not a conundrum if customers ask to add a false alarm filter to their existing system. They can easily replace with an AcuSense DVR from Hikvision's Turbo HD 5.0 product range, which makes the very most of legacy cabling. Accordingly, the system will be able to perform false alarm filter and quick target search across up to four channels. If customers have the requirement for more than four channels, they can either add extra AcuSense DVRs or Hikvision AcuSense network cameras.
With Hikvision, SMBs can take advantage of state-of-the-art surveillance systems in a way that suits their business needs and their budget. Equally important, the abovementioned different solution options can help system integrators and installers engage in new conversations with their customers.
To find out more about Hikvision's false alarm filter capabilities, please read a feature article HERE
Four ways Hikvision offers state-of-the-art false alarm filter to SMB customers
Discover more
