Hikvision Intercoms do not record on motion
marcus.spcc
Thread starter #1
Hi everyone,
I recently installed an intercom (KD8002-VM) and would like it to record on motion like any other camera. I have added it to my NVR under camera management and set the recording schedule to Alarm & Motion. After watching the intercom camera and seeing 3 people I did not then have any footage to replay.
Since then I have set the camera to record continuously and still have not got any footage on the NVR. Could iVMS4200 be putting the footage somewhere else because it is an intercom?
I have two other cameras in the same location able to record on motion and continuously without any problems.
Any help much appreciated!
Phil
#2
I have asked @Dan to investigate/respond when he is back in the office tomorrow
Dan
#3
Hi @marcus.spcc
I think @Phil thought this was a product we sell but unfortunately, we have never been hands-on with this specific product so won't be able to give much detailed advice.
I wouldn't expect iVMS-4200 to be an issue, if you can add the device to the NVR and it lets you set a recording schedule to continuous then I can't understand why it won't record, some of the smaller intercoms only support local MicroSD recording but this intercom model doesn't even support onboard storage.
The only thing I can recommend is to check that the Intercom is running the latest firmware.
macman
#4
FWIW, I haven't yet found a way to get my DS-KD8003-IME1 to record (or alert) on motion either. When a visitor pushes the bell, it records clips of visitors to its SD card but they can only be viewed on the indoor station. iVMS-4200 can't see or play them like normal clips (error 317 - no record file found).
But this may or may not be a MacOs failing.
marcus.spcc
Thread starter #5
Hi @marcus.spcc
I actually have two of the intercoms, one was set to continuous and did record to the NVR, once I set it to Motion | Alarm I have had no recordings, even though there has definitely been movement in front of the intercom.
Both the intercoms are on 181102, the latest firmware.
Dan
#6
Traditionally to record by motion, we recommend that you set the record schedule to just Motion and not Motion|Alarm and then you also need to make sure in the Basic Event Settings that motion detection is enabled and set up correctly. (see below - for better accuracy we recommend reducing the area of detection and adjusting the sensitivity)
