Hikvision Launch AX-PRO - Their Wireless Intrusion Alarm System
Status
Not open for further replies.
Emma Hedges
Hikvision have now launched AX-PRO - their own range of wireless intruder alarm systems.
What is AX-PRO
AX-PRO is a wireless intrusion alarm system which is completely driven by the Hik Connect app. Simple to set up and use, the compact and sleek design is perfect for use in homes, shops and offices offering a modern but discrete solution.
Hikvision use a dual-chip design to support independent communication between channels and to avoid interference, all the time ensuring the data transmission is reliable and secure.
The powerful Tri-X and CAM-X technologies help to speed up the installation processes for installers and their customers.
What products are available?
As AX-PRO is newly launched, at use-IP we have decided to keep things simple by offering six different bundles. Each bundle will feature an M or L Level Hub and 2 PIR Detectors and then various other add-ons to suit various set-ups.
L-Level-Bundle-1 - 1 x AX-PRO L-Level Hub, 2 x PIR Detectors, 2 x Keyfobs, 1 x Magnetic Contact, 1x External Siren (blue)
L-Level-Bundle-2 - 1 x AX-PRO L-Level Hub, 2 x PIR Detectors, 2 x Keyfobs, 1x Magnetic Contact
L-Level-Bundle-3 - 1 x AX-PRO L-Level Hub, 2 x PIR Detectors, 1 x Keypad,1 x Magnetic Contact, 1 x External Siren (blue)
M-Level-Bundle-1 - 1 x AX-PRO M-Level Hub, 2 x PIR Detectors, 2 x Keyfobs, 1 x Magnetic Contact, 1 x External Siren (blue)
M-Level-Bundle-2 - 1 x AX-PRO M-Level Hub, 2 x PIR Detectors, 2 x Keyfobs, 1 x Magnetic Contact
M-Level-Bundle-3 - 1 x AX-PRO M-Level Hub, 2 x PIR Detectors, 1 x Keypad, 1 x Magnetic Contact, 1 x External Siren (blue)
DS-PDPC12P-EG2-WE - Wireless PIR Camera which provides users with real-time motion pictures straight to their phones via Hik-Connect smart phone app.
What is the difference between AX-PRO L-Level and M-Level?
An AX-PRO system is centered around the main hub which comes in two ‘levels’, L and M. The levels essentially relate to the number of zones the system is intended to cover, as well as a couple of other additional features such as SIM card slots and onboard IP camera integration.
Below we have highlighted the differences between the L-Level-Hub (light) and the M-Level-Hub (middle).
That's all for now! If you have questions, as always you can get in touch via email, phone, forum or live chat!
Emma :)
  • AX_Pro_App_Brouchure.pdf
  • AX_Pro_Bundles_use-IP.pdf
  • AX_Pro_Product_Brochure.pdf
Status
