Hikvision NVR Lost Live View Sub-Stream, But Works On Camera Directly?
MetalEarth
I have lost my sub-stream after a reboot of the swtich/camera. I can be logged into the NVR and the camera at the same time. When logged into the camera I can view the main and sub stream no problem. When I select the substream in the NVR/configuration menu for the same channel camera, I get "The camera does not support the function." The main full resolution stream works fine. HikConnect app works fine as well.
IVMS4200 on a separate PC is also reporting Error Code HCNetSDK.dll[91].
To correct the issue of have:
-rebooted the camera
-rebooted the NVR
-removed and re-added the camera in the NVR
-lowered the resolution and frame rate for the sub-stream
No settings were changed, but the PoE switch was rebooted. I think I updated the switch firmware as well. I really do not want to reset the camera and set it back up, but that seems to be the only solution I am finding. More of band-aid really.
Thanks in advance for any help.
dazboj
I'm seeing something similar. I have 1 camera that every now and then disappears from my NVR. Plugging it into a different LAN socket brings it back. Now for some reason, I can view it full screen in iVMS-4200 but when I set it to a small window it says it has an error connecting. I'm assuming the smaller window is the sub stream.
