Hikvision nvr question
Loki_stg
If the nvr goes offline due to an issue with the network(internet died, dns issues, whatever..)
Obvious the nvr is inaccessible via the web and connect app. Should that video that is taken during that period be accessible via the app after the network is restored?
If I understand your question, you asked if internet access was disrupted would your NVR still record, right? The answer is yes. If there is some other problem that prevents your cams from talking to your NVR, no.
Basically I was checking my cameras from my phone. There would be periods where the system was offline. I was trying to determine if that cause could be network related or other.
That from those periods is missing. So the system is likely being powered off vice a network issue.
