- 4,976
- 113
Updated 24th June 2018 with fresh links to Hikvision download sites.
Unfortunately Hikvision keep changing their website/portal structure (which breaks the links) - if you find these links are broken, please let us know at support(at)use-ip.co.uk, Thanks
The latest Mac plugins for HikVision should be available from the European portal here:
DOWNLOAD PORTAL
The latest Mac version of IVMS-4200 is available here (sorry, the Mac version is mixed in with the Windows versions - look for the most recent dated update):
DOWNLOAD PORTAL
I have sometimes found a delay between new releases and them appearing at the European portal, so, just to be sure check at HikVision's international website:
Hangzhou Hikvision Digital Technology Co. Ltd.
Type simply mac in the search box.
You need to click the magnifying glass symbol to initiate a search.
Select 'Downloads' at the left.
You should see a few relevant results.
You may even see different results at the Hikvision .co.uk website:
SearchContent - Hikvision UK & Ireland
Same steps as above, if necessary.
The image below shows the latest/current versions available 1st February 2018.
DOWNLOAD PORTAL
DOWNLOAD PORTAL
