- 4,968
- 113
Everything you need to know about Hikvision's SADP tool:
(link to latest version download at the end of the text)
You can download the latest version of Hikvision's SADP tool from their portal here:
Version V3.0.0.160 for Windows PC users:
HIKVISION UK PORTAL
Version V3.0.0.160 for Apple Mac users:
HIKVISION UK PORTAL
- SADP is a basic software tool for finding Hikvision devices on your network
- It scans your network and looks for devices by MAC address - all manufacturers have a MAC address convention they can recognise as their own
- It will produce a table showing those devices
- One device per row in that table
- If you tick the box to the left of the row for any device, it will populate the fly-out at the right with the settings for that device - you can edit them there
- It allows you within that row to see lots of information about the device e.g. full serial number, current firmware version, IP addresses, etc
- By default SADP opens in a small pop-up view - you'll need to maximise it to full screen size to see all the info without a lot of sideways scrolling
- It is free to download - link at the bottom of this post
- Hikvision have now launched a new Mac version of SADP
- SADP stands for Search Active Devices Protocol
- It lets you activate and set a password for your Hikvision devices
- It lets you enter your router's IP address so that your device can join the network (Hikvision refer to your router as a 'gateway')
- It lets you either use DHCP to give your Hikvision device a valid IP address or set a fixed IP address of your choosing
- If you need to reset the password for a Hikvision device which does not have a physical reset button, then you will need to use SADP's 'forgot password' feature to export a file which you send to your supplier. They will in turn send this to Hikvision Technical Support and obtain a password reset file for you to import via SADP. Please note that when doing this - your device must remain powered-on from start to completion (the device's powered-on time is used as part of the security checks when resetting passwords) - click for our SADP password reset tutorial (NB - screengrabs are from an earlier software version)
- It will not show cameras which are directly connected to your NVR - only those devices on the same network as your PC (within the same domain range)
- The manual for this SADP software tool is attached below
- There's a video from our YouTube channel below that covers using SADP to find a Hikvision device on your network
HIKVISION UK PORTAL
HIKVISION UK PORTAL
