- Messages
- 4,973
- Points
- 113
Updated 30th October 2018 - corrected the download link in the last line (Hikvision had changed the url)
Firstly, has your camera got a pushbutton for resetting it?
It's a pretty reliable rule of thumb that if your camera has a memory card slot it will also have a reset pushbutton (often located adjacent to the card slot).
In HikVision's naming nomenclature an 'F' in the product code denotes 'F for Flash' meaning it can accept a memory card.
A few cameras in the previous R6 Family range have it.
All cameras in the current G1 Family / EasyIP 3.0 have card slots and pushbutton reset.
To reset your camera back to factory defaults:
When you check the camera in SADP after resetting it should show as 'inactive' and will require you to start afresh.
The first thing you'll be required to do in SADP is set a password.
All settings will be reset by a pushbutton reset, so you will need to re-configure the camera's IP address, network settings, time, OSD, etc.
We would recommend that you also check for and update to the latest available firmware for your camera model:
DOWNLOAD PORTAL
See also:
How to reset a Hikvision camera to factory default settings via your browser
- Disconnect the power supply.
- Press and hold the reset button.
- Keep holding the reset button and restore the power supply.
- Continue to hold the reset button for a further 10 seconds.
- Release the button and allow the camera to complete a restart/reboot.
DOWNLOAD PORTAL
See also:
