Human detection with Hikvision AcuSense cameras
samvol
Hi, I've bought this acusense model DS-2CD2046G2-IU/SL .
Hikvision site.
The latest firmware is installed (V5.5.134 build 200430).
There is the result of ISAPI/Smart/capabilities command:
SmartCap xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<isSupportROI>true</isSupportROI>
<isSupportAudioDetection>false</isSupportAudioDetection>
<isSupportFaceDetect>false</isSupportFaceDetect>
<isSupportIntelliTrace>false</isSupportIntelliTrace>
<isSupportFieldDetection>true</isSupportFieldDetection>
<isSupportDefocusDetection>false</isSupportDefocusDetection>
<isSupportSceneChangeDetection>true</isSupportSceneChangeDetection>
<isSupportLineDetection>true</isSupportLineDetection>
<isSupportRegionEntrance>true</isSupportRegionEntrance>
<isSupportRegionExiting>true</isSupportRegionExiting>
<isSupportLoitering>false</isSupportLoitering>
<isSupportGroup>false</isSupportGroup>
<isSupportRapidMove>false</isSupportRapidMove>
<isSupportParking>false</isSupportParking>
<isSupportUnattendedBaggage>false</isSupportUnattendedBaggage>
<isSupportAttendedBaggage>false</isSupportAttendedBaggage>
<isSupportPeopleDetection>false</isSupportPeopleDetection>
<isSupportSmartCalibration>true</isSupportSmartCalibration>
<isSupportStorageDetection>false</isSupportStorageDetection>
<isSupportChannelResource>false</isSupportChannelResource>
</SmartCap>
I concluded that my camera doesn't support human detection, or ,may be I'm wrong?
Of course, "human" checkbox exists in the menu, but there are a lot of false alarms caused by pets.
The question is, do I have to enable this option uploading edited xml ?
Or something wrong with firmware,camera ?
Thank you.
Hi @samvol
The AcuSense cameras do not support Human Detection as a dedicated smart event, the 'Human' checkbox you describe is part of smart filtering tool built-in to a selection of the cameras smart events to filter out all non-human triggers, but the detection is still not 100% accurate and to remove the majority of false detections from animals you will need to adjust event settings (e.g. sensitivity, min/max detection size, detection area position & size, etc...) as well as potentially using different smart events that are less likely to be triggered by in your case animals.
