Initialisation failure only when secured to mount - hikvision ds-2de4a220iw-de
Samstar85
After powering up, as expected the camera pans, then tilts, then moves to home position and sets, activating surveillance mode. As soon as this is done when the camera is on the mount, the camera seems to think the home location is on the opposite side, hits the farthest tip back point and knocks as its trying to turn past the point that it can.
Taking it down and holding the camera off the mount, works fine, soon as its put up it happens again. Any ideas?
Phil
That's an odd one.
In the same orientation? i.e. pendant under the mount / held pendant in your hand
Is it under any stress/strain when it's fitted to the base?
Any screws fouling?
Wires trapped?
Is the reset button exposed on that model? (seems unlikely, it would lose settings)
I think you may need to send it back to your supplier to investigate
