Door Entry IOS15 Hik-Connect App: Cannot answer call.
LeeBow
Hi all,
My intercom used to work fine - ios14, Hik-Connect app, intercom is DS-KH6320.
When someone rang the intercom - my phone would ring (wifi or 4g), I could open the app, talk to the person, and open the gate.
Now - since upgrading to ios15 - the phone rings (still wifi and 4g) - but when you click to answer the call - you are stuck on the Hik-Connect app splash screen.
I have this issue, my brother-in-law has the issue on his system. same hardware.
On another device on ios14 - the intercom still works correctly.
Anyone else with this issue? Has anyone found a fix??
Many thanks.
fin
Yes having the same issue, takes a few months for them to catch up with software updates
Bevwa1
Can I ask how you have your gate connected to your intercom please . I’m trying to connect the 2 wires from my old aiphone handset to the indoor monitor
fin
I think you have to wire them to the outdoor unit, I had to and always do on installs
fin
Which outdoor unit do you have and it it push to make or break on you existing setup?
Bevwa1
Hikvision IP Video Intercom Kit DS-KIS603-P(B) include DS-KV6113-WPE1 + DS-KH6320-WTE1 POE Doorbell Door Station WIFI Monitor
Aiphone ie-1du with L & L button live wires
fin
At the plug on the back of the external unit (the 6113) connect you original L&L wires one to the green and one to the blue, it doesn’t matter which way around.
