Thank you so much. NVR & camera are HIKVision.all camera and nvr in same network. i am monitoring 64 camera from 13 floor to B1 . every floor wired fiber . through fiver a Switch was establish and cameras are connected with switch in every floor in same network. NVR's are now setup different floor to monitor.Hi @alamin
What brand of NVR/cameras do you have?
How is your system setup? How are you trying to connect the cameras to the NVR? Are both the cameras and NVRs connected to the same network?
I have four NVR . all are hikvision. i connected all same cameras setup in four nvr . but at a time four nvr not work . 3 work out 4.Thank you so much. NVR & camera are HIKVision.all camera and nvr in same network. i am monitoring 64 camera from 13 floor to B1 . every floor wired fiber . through fiver a Switch was establish and cameras are connected with switch in every floor in same network. NVR's are now setup different floor to monitor.
problem not solvedYou can add camera's to another NVR via rtsp?
