IP camera works with DVR but can't access main or sub streams via p2p
Keiranj85
Hello I was wondering if someone could help with an issue I'm having. I have a Dahua DHI-HVCR4108-HS-s3. I current have four cams hardwired but didn't want to ruin a newly renovated room drilling so have opted for an IP camera hoping this would solve the issue.
I purchased a SV3c IP camera. I've set it up and my DVR finds it no issue. Recording the stream sent but I cannot access the main or sub via my normal app. I use gDmss lite and I can access the existing channels no issue but when I try to access channel 8 which is the IP camera it loads for literally half a second and crashes the app.
I don't understand what I'm doing wrong and have been through ever single setting configuration and cannot see the issue.
Like I said it's recording fine and I can view directly via the unit or web login on my PC etc but I can't access the channel on the app. I've tried four different apps now. If someone could help or give me some advice it would be greatly appreciated. Thanks
