PoweredByVeg
- Messages
- 80
- Points
- 8
I installed version .016 yesterday and don’t appear to have any issues with 6 x G1 cameras attached. Hik-Connect appears to be working without any issues too.
I appear to be stuck with this broken firmware now, as I can neither upgrade to NVR_K51_BL_ML_STD_V4.40.016_200803 nor downgrade (I've tried NVR_K51_BL_ML_STD_V4.22.005_200327).Hi @rickwookie
We tested this ourself with a 2385 turret connected to our 7716NI-I4 NVR and we saw a very similar problem and we hadn't had problems streaming 8MP cameras from this NVR before so we assumed it was probably related to an update in one of the recent v4 firmwares. We took this issue to Hikvision support, they asked to remote access our NVR to take a look at the issue and after some fiddling with many settings the stream did improve but to make this improvement as you will see from the Hik Support response below they had to drop the resolution:
From the test, we can see the stream freezing issue can be solved by lowering the camera resolution, which means the issue comes from the network environment. I would suggest the customer lower the mainstream resolution and change the encoding format to H.264. If he insists to live view 8 MP video on Hik-Connect, he can configure DDNS which can improve the video. Please find the relevant how-to document in the attachment.
Obviously, lowering the resolution is not a great solution (especially when they had to drop it to 720p to stream smoothly) and so for the time being if you absolutely need the 8MP resolution on the mobile app you will have to port forward your NVR and add it to the app with DDNS, you can do this using the documents attached.
We were not happy with this answer and we asked that they pass this on to their R&D team because I assured them we have not had problems streaming 2385 and other 8MP cameras through this NVR on earlier firmware and that the problem has only appeared when a recent firmware was installed. (we are not 100% sure which version introduced the problem as we are a version behind v4.40.015) Hopefully, they will investigate further and solution will be introduced in a later firmware update.
Me? No, I have an I series NVR.Are you trying to upgrade a K-series NVR with I-series firmware?
Via the (otherwise working) web interface I get to about 33% and then get "Upgrading failed" every time, and trying the TFTP method the NVR just seems to get stuck in a reboot loop:
If I then shut down the TFTP server and power-cycle the NVR, it eventually comes back up unchanged - stuck on this crappy firmware but unable to ever get off it.
You mean like a really old V3 firmware? How small does it need to be?I had read that the Hikvision TFTP server cannot handle large firmware files so that might be your issue. You can't use a different TFTP server either as this is customised. So an option might be to downgrade to a much earlier version (ie smaller file) and then upgrade vis the Web interface to the version you want.
Ok, well, yes, Using the newest version I could find under 30 MB did indeed work via the TFTP tool, so now I have NVR_Hi3536_BL_EN_STD_V3.3.9_151228 on there. The problem...I believe the Hikvision TFTP server requires the firmware to be under 30 MB, so likely yes you have to go back to a very early version via this mechanism (which will reset the NVR to default), and you can then upgrade again once you gain access.
If you are still having problems and would like some help, can you start a new thread please.I had 4.22.005 on until an hour ago tried to upgrade to the 2mp version of 4.40.016, then normal version of 4.40.016 then tried normal version of 4.40.015 and all of them had my unit offline despite my PC able to talk to it and it send test emails, each time I uploaded the confit file I saved before I started but it still want sort it. I checked all the setting as posts on here and checked the serial number was correctly listed at www.him-connect.con and it was I’ve now gone back to the original version I had on 4.22.005 and upload the confit file also and it’s staying offline and I cannot get it to reconnect. Anyone any ideas?
Well, looks like this may be the issue address with V4.40.017 build 201124:Another new bug that I'm now seeing is that the timezone setting is being ignored and seems to be stuck to GMT+08:00, so I can't now use NTP, I have to use manual setting, which will no doubt drift out over time.
