- Messages
- 4,223
- Points
- 113
[20/07/20 - IMPORTANT - Some users updating to this firmware have reported that their NVRs have reset after updating, this does not appear to be affecting all K-series NVRs but if you are worried about losing any NVR/camera settings you can always go to Maintenance and export the NVR/Camera parameter (config) files]
Hikvision has released new firmware for their K-Series [76 77 86 NI-K2 K4 K8] Network Video Recorders. The latest firmware, Version 4.30.005, can be downloaded here.
The Release Notes can also be found via the link above.
Below is a summary of all the new features, each is explained in more detail in the release notes.
Reason of Upgrade
New features
2.【Support access in ISUP 5.0 protocol】
5.【Support GUI local online upgrade by Hik-Connect】
6.【Support event recording search in Hik-Connect client】
7.【Support two-way audio function with Hik-Connect】
8.【Add Right-Click menu】
9.【Add online and offline status display of IPC in Web】
10.【Optimization of PoE exception information display】
11.【Adjustment of access mechanism of main stream and sub-stream in Hikvision protocol】
12.【Local playback】
13.【Authority management】
14.【Optimization of storage】
15.【Password of IPC activation equal to NVR password by default】
16.【NVR disable Smart VCA by default】
Modified functions
1.【Optimization of operation】
Fixed issues
1.【Fix the issue that GUI interface exception】
2.【Fix the known defects】
The most noticeable improvement with this firmware is the introduction of the new GUI called E-UI (Easy User Interface) which is quite a drastic change both visually and in terms of features from what we had before with the V3 GUI, see a walkthrough of the new layout and some of the features in the below video:
As some will be aware this new interface had already been released on the 7604(B) NVR, when that happened we asked some clarifying questions to Hikvision support to understand everything that was being introduced with this new V4 firmware. The 2 most important answers we got are below:
E-UI firmware supports human/vehicle filtering only for motion detection, not all the AcuSense functions.
Currently, we don’t have a plan for K-series NVR plugin-free solution.
This is why Hikvision calls the firmware V4 Lite because although it does include some of the functions/features of the full V4 firmware we have had for a while on the I-series NVRs, it will never be updated to the full V4 due to hardware limitations of the K-series models.
Reason of Upgrade
New features
12.【Local playback】
Modified functions
Fixed issues
