Firmware Latest Milesight Firmware for NVRs (V7x.9.0.7-r3) and Cameras (V4x.7.0.73-r7)
Kyle
Thread starter #1
Milesight have recently released new firmware for all of their NVRs and cameras. The latest firmware updates can be downloaded here from their Download Centre.
The Release Notes are below:
Firmware for cameras:
  • Support to adjust the sensitivity of Day/Night switch on 180¡ã Panoramic Mini Bullet and New Mini Bullet;
  • Support to display "Sum" and "Capacity" of People Counting;
  • Support to save LPR snapshot into SD card;
  • Optimze the memory reclaims;
  • Fix the problem that the PTZ Bullet Camera fails to tilt down when using 3D positioning function;
  • Fix the problem that you may fail to login after upgrading to version 4X.7.0.73 with IP parameters changed;
  • Fix the problem that Auto Tracking still works without setting the Schedule;
  • Fix other bugs.
Firmware for NVRs:
  • New feature: Private HDD in Storage->Disk->Edit.
  • Fix APP message push issue;
  • Fix Video Loss failed sending email issue;
  • Fix the VCA track missing issue on live view of local display;
  • Optimise the prompt for 3rd party Motion Detection;
  • Effective time and action settings changed to be configurable even when motion detection is disabled;
  • Milesight Fisheye camera 4R mode Motion detection limit;
  • Security upgrade for TLSV1.2
jamesb
I've not been able to update the firm on my NVR
model UI-1009-PA
current version: 72.8.45.6-2
I've tried updating to 72.9.0.7-r3 (from the milesight download center) but consistently get the message 'Upgrade unsucessfully!' after a couple of seconds. I've tried a factory reset, formatting harddisks etc, but the message is always the same.
Any tips on how to update the firmware on these devices?
Dan
#3
Hi @jamesb
You are several versions behind on NVR firmware, Milesight introduced a key firmware over a year ago that has to be updated to first before you can go beyond it, see the below forum post for more information:
jamesb
thank you! your advice did the trick, I've managed to upgrade now
