- 5,013
- 113
Update 4th April 2019 - superseded by a newer version:
Latest version of Hikvision's SADP tool for Windows users (V3.0.1.4)
You can download the latest version (V3.0.0.160) of Hikvision's SADP tool from their portal here:
HIKVISION UK PORTAL
The corresponding latest version of the user manual is attached.
NB - You can access the user manual from within SADP; click on the info icon at the top right, and then the 'User Help' link.
(BTW note it shows as .16 rather than .160, but the build date of 23rd March 2018 is newer than the previous .100 version)
A couple of further points:
Hikvision are now using .rar as their zipped file format - you will need to install a tool such as '7-zip' to extract the files from these compressed .rar files.
When you run the SADP install, the first pass will uninstall any earlier versions of SADP you have installed, the second run will install this latest version.
Hope that all helps ...
You may also want to check this other Post on how to reset your Hikvision camera or NVR's password using SADP
HIKVISION UK PORTAL
