Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hi guys, can Hikvision turret cameras be mounted on vertical walls ? I want a camera on the wall above my front door
Thanks Dan, the wall is probably around 12” thick , I want the camera above the front door of the house looking over the cars on the driveway plus a car parked on the road at the end of the drive approximately 30 feet from the front door.
After doing a bit of research I’m leaning towards a dome camera , but which one would you guys recommend, I think probably a 2.8mm as the cars on the drive are only a couple of meters from the house and the two cars are side by side plus one car on the road which is around 10m from the house.
