Need spare pair to prevent cable change
Porsche0911
I have a hikvision ds-2cd2042wd-i 4mp camera my cat 6 cable has a split pair error 1/2. Can I replace pair 1/2 with another unused pair. I am running PoE with a DS-7604NI-E1/4P
David
@Porsche0911 is it a homemade cable? If the rj45 connectors are clear plastic you should be able to see the bad end and replace it.
Porsche0911
It was a purchased cable. I had a split 1,2 error on the tester. Chanced both ends and had the same split 1,2. switched blue and brown pair and cable tested all pairs OK. The camera is running now.
David
data / poe is usually on the green / orange pairs. I wouldn't buy another patch cable from that company.
