NVR,s
james 415
Thread starter #1
Hi All.
I have 4 x DS-2CD1341-12 hikvision ip domes, can I record these only on a hikvision nvr.
or are they compatible with any main stream nvr.
many thanks James
Dan
#2
Hi @james 415
As long as it is an NVR that supports ONVIF you will be able to connect the above camera model, adding certain cameras with ONVIF will limit the smart features you have access to but this entry-level Hikvision model has very few smart features so there will be very little difference between using it with a 3rd-party NVR and a Hikvision NVR. If you did want to use it with a Hikvision NVR we would recommend the 7604 4-channel NVR
27901591
Majority new NVRs support ONVIF, you'll just have to configure it manually, i know with some hikvision cameras you'll have to go into the setting via internal ip address and turn on the onvif setting.
Installer at: IseeU CCTV
Mobile: 07903322632
Web: www.iseeucctv.co.uk
Email: Info@iseeucctv.co.uk
