Nvr wont power certain ip cams
Dwaynemps
So... upgraded from a 5mpPOC set up to 5 ds-2cd2385G1’s, I have a previous G1 and a auto tracking PTZ that were running via POE switch,
Today comes swapped everything over and the NVR wont even power the cameras that have been previously set up via the switch,
I have restored these and they will only work via the switch but will not connect to the NVR,
Has anyone had the same issues? If so what was the fix?
Just to add SADP keeps saying timed out
Can you test whether the NVR will POE-power a camera with a short patch lead please?
A lead that you have purchased (factory-made).
I will pull the cams down tonight and try this and report back
Found the issue Old cams installed via previous crap installer (Hope he reads this):p 2 wires crossed, will grab some more ends tomorrow and re connect
