Replacement for JVC TK-S240 analog indoor camera
I would check with that vendor.
Yours is an old/traditional analogue CCTV camera; composite video ~ 1 volt peak-to peak
I would avoid anything that tries to deliver higher resolution e.g. TVI/CVI/HDI/AHD unless you are also replacing other components to match e.g. recorders and monitors.
Thanks. Vendor if what? JVC? Are they even in business.
If you meant the DVR then it's a modern digital system Exacq (I think), so there's an analog-to-digital converter there. I was just asking about the connectivity and voltage and whatever else is needed for that old analog camera setup.
