Seesii 8600 IPC TESTER
Habf643
I have a Seesii 8600 IPC tester ( please send me any advice if you have a different kind of ipc tester)
All the apps have been erased . I can not do anything while the tester is on.
But I do have the apps on a SD card.
How do I get into download mode?....
( I.e. I turn off the Seesii and hold down certain hard buttons while i turn the Seesii on?)
Please submit any advice or suggestions
I have a Seesii 8600 IPC tester ( please send me any advice if you have a different kind of ipc tester) All the apps have been erased . I can not do anything while the tester is on. But I do have the apps on a SD card. How do I get into download mode?.... ( I.e. I turn off the Seesii and hold down certain hard buttons while i turn the Seesii on?) Please submit any advice or suggestions
Use the file search on the tester if you have the file they should be .apk format click on them as you would any other android file.
Hi I have the same issue with same tester as yours, have you managed to get it resolved. If so are you able to share how you did.
