@David its not super remote probably about 1 km from the working office, Its power that is the issue@dturtill I've worked on remote solar powered Telecomms sites and should be able to help.
How remote is this site and will it be 24/7 operation?
I have setup systems before that run on leisure batteries and things just saw this and thought it was a good price
I have used external chargers and things, the only issue with these is the constant need to change batteries and supplies, I have managed to get a setup where if it gets low power then timelapse still works but remote feed doesn't until the power increases so will give this system a try and see if its any betterIt lasts 7 days on a fully charged battery, winter may be a challenge needing occaisional site visits to change / charge the battery. As you've built your own systems what about a separate camera with your own solar / wind / external dc charger?
Will the camera 4G signal be good enough for a 24/7 connection?
After looking at the video and specifications I'd buy this. Use your smartphone to check the 4G signal level where the camera will be, a steady signal level of 3 bars should be ok.I have used external chargers and things, the only issue with these is the constant need to change batteries and supplies, I have managed to get a setup where if it gets low power then timelapse still works but remote feed doesn't until the power increases so will give this system a try and see if its any better
@Dan i can’t find the hikvision webpage now but this was marked EOL. Is this a mistake like the 4K acusense camera?pdf attached
