Stay on Main stream (Solved)
Calvinder
Hello
I have a DS-7608NI-E2 NVR and I would like to be able to keep the images on the multi screen in main stream mode. If I set them to main stream as soon as I go to a different view and go back to multi view they default to sub stream.
I have tried to find out if this is possible with no luck.
cameras are DS-2CD2041G1
Thanks for any assistance
Calvin
It is likely that this model NVR does not have the capability to show multiple cameras at once in high-res, so it reverts to their sub-stream.
You may be able to increase the resolution of the sub-stream settings.
But at some point you are likely to run into an issue with one pane not populating and displaying No Video / No Signal.
Hi Phil
If I set them all on Main stream (I only have 3 cameras) and don't go away from the multi screen they are fine all day
Good idea to see if I can up the rez in the sub stream thank.
Found it :)
I found it by accident I went to Menu, Configuration, Live view in left, View tab, More settings tab, Then select Stream type for each camera from Auto to Main.
