Hik-Connect Tv viewing of cameras
Dominic100
Hello, I have just moved my NVR to a services room. The IP cameras all route to to a POE switch in the services room and then connect to the NVR via a Cat 6 cable into the uplink port of the switch. All works good.
We have a large smart TV in the kitchen where we would like to be able to view the cameras on and if possible toggle between the images.
We have a Cat 6 cable running from the kitchen TV to the switch in the services room.
Would it be possible to utilise this Cat 6 cable for viewing on the kitchen TV. Thanks for any advice.
If your TV has internet access then you could login to the NVR's web interface which will be the IP address of the NVR.
Or if not then if you can connect a small computer at the back or maybe an amazon fire stick, you may be able to load Hik-Connect on to that. Youll need to check if the app is available for whichever device you have connected.
