using a Fibre network for CCTV IP Cameras
acs21
HI
I have a requirement to run an IP network 600m with 5 POE cameras connected to POE switches 5 at one end, then 3 switches every 200 m along the run.
nvr---x -----x-----x------x
Each x is a switch with a 200m fibre between each one
I've tried looking into this with suppliers but they wont give the whole solution ( they say i should know what fibre cable to use?)
help!
Do you need the three mid-point switches for other purposes?
i.e. you are aware that fibre will go 600m if you wish?
Whichever, we can sort you out with the parts required.
HI
this is a network for IP CCTV there will be 5 POE IP cameras at each of 4 switches (7W per camera POE)
