Viewing and saving playback footage using Axis Camera Companion
Harri Whipp
Now that you have cameras connected you can view any footage that has been recorded. In the top left of the screen, click the playback button:
You will be taken to the main playback interface, where you can view recordings, search for an event and save the footage.
At the bottom-center are your main controls. You can play, pause and skip through footage using the button or the slider. You can also play footage at a faster speed by scrolling over the play button which brings more options up.
In the bottom right-hand side there are two more buttons. The one on the left will open the ‘Video Inspection Window’.
This allows you to skip to the part of the footage you would like to inspect and will also provide screen shots of what was captured immediately before (-30,-15,-5,-1), as well as screen shots of what happened immediately after (+1,+5,+15,+30).
You can save a screen shot by clicking the camera icon in the bottom right-hand side.
If you exit the inspection window, to the bottom-left of the main playback screen you can choose the day you would like to view by clicking on the calendar button.
The second of the two icons (which looks like a floppy disk) allows you to save footage directly to your computer.
Once you have clicked the icon, you can choose what part of the footage you would like to save.
Once you have chosen the footage you would like to save, click the ‘Save’ button.
Your footage will now begin to save to your computer.
Once the footage has saved, the folder containing the footage will open. You can then double-click to view it.
