Ime using a NVR DS-7716NI-14B . I knowthe QR codes for Hik connect are on the bottom of the cameras but is there anyware else I can get the from. iVMS made it easy, youing a NVR I can work it out.
Do you have access to the serial numbers for each camera? You can find them on the box labels or just scan for the cameras on your network using the SADP tool to find them.
Then, press the small + on in the top-right corner of the mobile app to add the cameras manually using the serial numbers.
