Wireless link problem
Tambroon
Hi. Ive just installed a hikvision ptz camera in a barn using nanobeam wireless bridge to the nvr in the house. Iv got it up and running with the nanobeam plugged into port 1 on the nvr. Im now trying to connect a second camera in the barn using the same wireless bridge using a 4 port switch at the barn but cannot view the second camera. Do i need a switch at the house end to have a camera pugged into port 1 and 2 of the nvr or do i need to do something else
You need to extend your LAN with the wireless bridge.
You cannot use it via the camera ports on the NVR.
So, in the house, connect the wireless bridge to your LAN.
In the barn, add a switch to the wireless bridge.
Add cameras one at a a time.
Use SADP to find the cameras, and assign them with general LAN IP addresses.
Then, with your NVR also connected to your general LAN, access it from a browser and add the cameras manually (by telling the NVR at which IP address on the LAN to find each camera).
