Axis T8331 Indoor PIR Motion Detector - 5506-931
SKU: 5506-931-EOL
Whilst it has not been superseded by another products, please feel free to browse the wider range of AXIS products that we have to offer.
The Axis T8331 is an indoor PIR motion detector which allows your camera set-up to react to motion within its visible range, this is an advantage to smaller systems as you can set your system only record when motion is detected which saves on storage space and bandwidth, as well as extending the period of time you can keep stored on your NVR or NAS. The passive infrared technology used in this motion detector makes it much more accurate with less false alarms than any older models. The T8331 is simple and quick to set-up with its single cable design and the included tripod mount makes it easy to mount to any standard wall bracket.
- Installation Guide
- Tripod Thread Bracket
- Mounting Bracket
Axis T8331 User Manual
Axis T8331 Installation Guide
Axis Product Comparison Table
- Limit false motion detection
- Lower storage & bandwidth by only recording when motion is detected
- Easy plug & go connectivity
Dimensions
Compatibility
Detection Field of View
