Hik-Connect DS KV8113 WME1. Hik-connect offline after power off then power on?
I had the exact same issue with the same door station on the same firmware as Hikkups, i found that if you connect the network cable, then set the ip address to DHCP, then restart the station. unplug the network cable and you can restart the station without losing the IP address. what I then did was create a static DHCP reservation on my router to ensure it got the same address every time. disconnected power several times and so far it seems to always come back on WiFi with the correct address and shows up in iVMS and SADP correctly and editable.
