Firmware Update G5 firmware - V5.7.14_231213
Me too. Just loaded 5.7.15 onto DS-2CD2047G2-L(2.8mm), DS-2CD2047G2H-LIU(2.8mm)(ef).
No problem with DS-2CD2047G2-L(2.8mm) that is not included in release notes.
Of course I would like Mosaic type be chosen in Privacy Mask function for IPC 2 series too.......
Also loaded to DS-2CD2387G2-LSU/SL and DS-2CD2387G2H-LIU. Not noticed any issues so far.
LocalServiceComponents has also been updated to version 1.0.0.97 which you can get if you download Plugin from your camera.
Agree with regards revisions, it is getting very confusing. What is eF !!
Could be random, but did anyone with NXI NVR notice an "automatic" change for Smart Events as VCA By NVR?
Noticed after missing rules regions in NVR settings only on Hybrid DS-2CD2047G2H-LIU.
Also detection sensitivity seems reduced
The release notes state the camera boot time will be faster with this firmware.... I didn't time it before I upgraded, but the cameras do seem to load a bit faster.
DS-2CD20(2)(4)7G2-L(U)​
Firmware_V5.7.15_240411
No release notes. Seems faster on boot-reboot
**** Check this before install:
I'll await something on the UK website before updating. Many of the G5 models are still showing 5.7.14 still in the firmware area of the website.
UK Product page for the DS-2CD2366G2-IU is now showing
As usual, the 2.8mm and 4mm are showing differing build dates.
As clear as mud then. More often than not we’re seeing different firmware builds listed for different model variants using the same firmware platform version. I’m not sure if that’s intentional or not. The newer build will no doubt load onto any G5 camera regardless of model.
I've just tried the new build (240411) on several 2387G2H-LIU, 2387G2-LU and it works fine. This new build adds 'AcuSearch' tab to the 'System Settings' page. The new function defaults to 'on' and the Metadata Settings > Smart Event now defaults to 'off'. Clearly AcuSearch will do nothing until corresponding NVR firmware supports it.
Can you check Live View on your NVR, Human shows a Hxx and Vehicle possibly a Vxx, over target tracking rectangle?
On iVMS4200 I disabled Display Transaction Information as Jake Hulks suggested on another post
Yes it does. With VCA overlay on, the target tracking rectangle shows for both Human and Vehicle. I don't have Vehicle selected in my event setup, so for vehicles just the rectangle is shown in green. For Human however, the rectangle switches between green (human detected), red (alarm) and cyan blue. The cyan is new and when that's displayed a code appears above the target that appears to be relative to the size. Coming into view the number increase and then decrease as it passes (from H1 up to H10 then back down again)
An update to 5.7.15 240411
Detection issues again. Watching same thing for two days.
Wife going out, walking on a straight line, entering and crossing 5 different regions and lines, but is not detected. Me going out 2 minutes later, walking same way, detected on all regions and lines, giving alarms. Experimented with target size, min max, but no difference. Wife loitering inside same regions, hardly detected and mostly on Line crossing. House sparrows, blackbirds and cats are detected all times and give alarms. Motion detection on the other hand, works OK.
This is very difficult to verify and this reminded @Ianc issue a few weeks ago
Thinking of reseting ColorVu again or go back to 5.7.14
