- 4,206
- 113
They look fine to meI’ll give those a try. I’m attaching some images of my scenes using what I think are the best settings. Do you think anything could be improved?
When the cameras are set to auto day/night that's what you will get and as you've found you have to find a balance. The only way around that is to use a different image profile for day and night and that cannot be automatic; it either needs to be timed or commanded. Using the image profiles you can have different exposures, image settings, gain level etc.The issue I’ve noticed, well not really an issue. Fine tuning say the contrast and sharpness in the day, makes the image look poor at night. I get it’s all about finding the balance.
They can be timed to switch but as sunrise/sunset are drifting on a daily basis, you'd need to use something like @johnfitzy 's app which allows you to set your location along with an offset to sunrise/sunset and sends the times to the cameras. You then need to just alter your settings to suit.
I do it a little differently and use the light level from an external sensor to trigger the camera between three modes - one for day, one for night and one for low light (dawn, dusk, overcast). That's more complicated and requires other systems and settings.
Regardless of the above I wouldn't spend too much time chasing the perfect picture - it doesn't exist.
