Need Help Finding the latest firmware for my Hikvision DS-7104HQHI-K1(B) DVR
Perfect!
That means that I am safe using 4.30 firmware.
Many thanks for helping me!
And the official answer from HIKVision support team:
Dear customer,
The latest firmware for DS-7104HQHI-K1(B) is K72A v4.20.001 build 190430.
K72A v4.30.101 build 191120 is not for this model.
Please downgrade, thank you
There is a new firmware:
- V4.25.000 build200925
But there is no Release Note.
Did someone installed it?
It's OK for DS-7104HQHI-K1(B) DVR?
There are 4 ranges of firmware versions, on NL Portal:
V4.30.120 Build200630 - 2021-05-03
V4.25.000 build200925 - 2021-04-12
V4.21.100 build 200307 - 2020-06-15
V4.20.001 build 190430 - 2019-09-20 - I have this one installed and it runs OK
Witch one I can use for my DS-7104HQHI-K1(B) - K72A - DVR?
Where can I find the answer?
Can I upgrade from 4.20 to any newer version, like 4.21, 4.25 or 4.30 ?
My DVR model is: DS-7104HQHI-K1(B)
Thanks!
Hi @apashi
We don't have much hands-on experience with DVRs and analog products, so we would probably just suggest that you update one firmware step at a time and then if the install is successful you should check all the settings/menus that you regularly use to make sure you haven't lost any functionality, before then stepping up to the next firmware.
