Door Entry Help needed for Intercom DS-KD8003?
Finally - i manage to set it as an online. Thank you for you patience. Next question is - how to set it comunicate directly with a Mobile phone. Is it possible? Tutorials on The Internet use internal monitor to achieve that.
Hi, sorry for reopening this thread. How did you manage to set the device as online? Thank you for you patience.
Ok sorted it 24 hours later. So I had to go to the hikvision web site here
DS-KD8003-IME1(B)
then download the latest firmware_V2.2.75_231213
Then extract it to my pc. The use SADP tool double click the ip address of my intercom. The login using the opened web browser I used edge on win 11. After logging in select configuration at the top and maintenance on the left.
Next to upgrade I selected “controller “ then pointed the import file to where I had extracted my firmware file on my pc. Then I waited 5 mins while it patched the bios and rebooted. Once it did that when I added it in iVMS it showed online. Hurraaa…
Argh same situation but It doesn't open the IP address in any browser. Do you know any other way to upload the firmware? Tried every tool of hikvision, even the web client online which is like a VMS.
Thank you for your patience
Also trying to upgrade the firmware of the indoor station, which is possible because is online, and fail to. I'm going crazy
